we are migrating thingworx from on prem to azure, thing Worx installed with mssql server database. I am installing mssqlserver database in azure vm,
now I have the doubt of while creating sql server instance and database name, do I need to give the same sqlserver instance and database name exactly like on-prem? If we give same names, then is there any impact?
KSM
Hi @KSM ,
you can give them different names, this will be ok, using the same names can simplify the migration process and minimize the impacts.
regards
Yasin
