I am displaying data on collection widget after selecting one template from drop down. when i scrolled up and down some rows are get disappear or lost the data of those rows. this is happening when I run mashup,
Hi Prem,
Try to change the collection widget property UID with different field like name which should be represent unique in the data. your issue will get resolved.
for the above query am attaching the image also how my mashup is behaving.
Im also got into the same issue. did you find an answer?
regards
Prem
Hi Prem,
It works, Thank you!
