where I could find thingworx.war release 8 for training ?
Re: where I could find thingworx.war release 8 for training ?
I have full rights  and always same pb
Is your ThingworxPostgresStorage folder empty?
Hello
I have installed PostgreSQL 9.4 instead of 9.6
In the installation guide, I execute the thingworxPostgresDBSetup.bat where I have added "To set up the database and tablespace with a default PostgreSQL installation that has a PostgreSQLdatabase anda PostgreSQLuser name,enter:thingworxpostgresDBSetup –a postgres –u <PostgreSQL user role name>–l C:
\ThingworxPostgresqlStorage  where <PostgreSQL userrole name>is the user role name that you entered in previous steps.
REM Run psql
psql.exe -q -h %server% -d postgres -U %adminusername% -p %port% -v database=%database% -v tablespace=%tablespace% -v username=%thingworxusername% -v tablespace_location=%tablespace_location% -f ./thingworx-database-setup.sql
thingworxpostgresDBSetup –a postgres –u adminPGSQL –l C:\ThingworxPostgresqlStorage
pause
but I have an issue about psql.exe :
Do you know why please ?
Thank you
Isabelle
Hi Isabelle,
Could you please verify that the PostgreSQL installation/bin folder(C:\Program Files\PostgreSQL\9.4\bin) is added to the system path variable.
Hello, I have updated my installation environement with all your help notes and thank you to everybody.
but always white page for thingwoarx application
Application logs indicates : 017-08-30 12:14:28.909+0200 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-86] Could not handle request
Isabelle
Hi Isabelle,
Could you please verify if the platform-settings.json file has the correct password (password created in the pgadmin3 tool) for the twadmin user.
I have "password": "password", in the file and I set this password agin in pgadmin for twadmin. I stop the application thingworx in tomcat, then I start it again and always nothing. I join traces : last sotp 15h22 : 0-Aug-2017 15:22:03.104 INFOS [http-nio-80-exec-84] org.apache.catalina.util.LifecycleBase.stop The stop() method was called on component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/Thingworx]] after stop() had already been called. The second call will be ignored.
and application.logs
Thank you
application logs joined
Could you provide a screen shot of your pgAdmin tool , please expand the Databases ,Tablespaces and Login Roles .
Hi Isabelle,
Could you please share the PostgreSQL logs (<postgres_install_point>\<version>\data\pg_log>) as well?
here it is
Hi Isabelle,
Could you please share the platform-seetings.json file? Also, please use the twadmin user and password  for  username and password variables in the file as shown below:
"PersistenceProviderPackageConfigs": {
"PostgresPersistenceProviderPackage": {
"ConnectionInformation": {
"jdbcUrl": "jdbc:postgresql://localhost:5432/thingworx",
"username": "twadmin"
I have not twadmin like you but my adminPGSQL, created during installation : page 10, 3-b :
b.Select NewObject>New Login Role. On the Propertiestab, in theRole namefield, enter the <PostgreSQL user role name>for PostgreSQL administration
I have modifed the platform-settings.json : "username": "adminPGSQL" ... but same thing
How can I change the thingworx in pgadmin to put twadmin like you ? bes=cause I use this adminPGSQL in . DBsetup and Schemasetup . bat
and why create the 3-b ?
I have "2017-08-30 16:56:09 CEST FATAL:  authentification par mot de passe échouée pour l'utilisateur  « twadmin »"
--> 2 admin twadmin configured and my adminPGSQL created as asked by the installation but I think we don't need it ?
Yes , you don't need it, just keep the postgres and twadmin users. Give the twadmin credentials in platform-settings.json.
Did you make any changes to the thingworxPostgresDBSetup.bat file?  Can you share the first few line from your bat file?
SET server=localhost
SET port=5432
SET database=thingworx
SET tablespace=thingworx
SET tablespace_location=C:\ThingworxPostgresqlStorage
SET adminusername=postgres
SET thingworxusername=twadmin
SO I have delete the table thingworx in pgadmin, my user adminPGSQL, I have modify again . bat and settings, and I have launch .bat
and I have also put password for posgress password to launch .bat
I noticed that your platform-settings.json has more than one persistence provider configured. Could you try with just the postgres persistence provider package?
WhenI have installed Postgress, I have chossen a password, and it is not password as for postgres and twadmin. Is is the problem:
017-08-30 17:24:58 CEST FATAL:  authentification par mot de passe échouée pour l'utilisateur  « twadmin »
2017-08-30 17:24:58 CEST DÉTAIL:  La connexion correspond à la ligne 80 du pg_hba.conf : « host    all             all             127.0.0.1/32            md5 »
Yes, When you install Postgres, you will be prompted to enter the password. This is the password for the postgres user .You need to give that password when you run the thingworxPostgresDBSetup.bat .
And when you run the thingworxPostgresSchemaSetup.bat , you will be prompted to enter the password of twadmin. So here , you need to enter the password you gave while creating twadmin in the pgAdmin tool.
- I have update my platform-settings.json with only the postgres persistence provider package
- I didn't create twadmin (neither postgres), it was already created. I updated rights to all for both.
Always the same error : 2017-08-30 18:39:45.896+0200 [L: ERROR] [O: c.t.s.a.AuthenticationFilter] [I: ] [U: ] [S: ] [T: http-nio-80-exec-142] Could not handle request
and :
2017-08-30 18:39:27 CEST FATAL:  authentification par mot de passe échouée pour l'utilisateur  « twadmin »
2017-08-30 18:39:27 CEST DÉTAIL:  La connexion correspond à la ligne 80 du pg_hba.conf : « host    all            all            127.0.0.1/32            md5 »
it is very difficult to install such application
Hi Isabelle,
I'm sorry that you are facing all these issues .
1) Could you please try removing the MSSql Persistence Provider package too, from the platform-settings.json?
2) Then run the thingworxPostgresDBCleanup script file.
3) Now delete the PG_9.4 folder in your ThingworxPostgresqlStorage .
4) And finally run the thingworxPostgresDBSetup.bat . Let me know if the thingworx database gets created.
thanks Janet
So no more mysql provider in platform-settings.json. do I keep others information ? "PostgresPersistenceProviderPackage ...
the thingworxPostgresDBCleanup script file clean s n PG_9.4 folder and in pgadmin
hingworxPostgresDBSetup.bat .  creates again thingworx database in ThingworxPostgresqlStorage  and in pgadmin
but always same issue for the appli
Hi Isabelle,
Did you try executing the thingworxPostgresSchemaSetup.bat file next? Are you getting any error while doing so?
yes I have executed also thingworxPostgresSchemaSetup.ba
Now I have regressed, my localhost (tomcat) to launch the application is unaccessible.
question : why have I a connection role named twadmin because I have never created it .... I can see the postgres, I suppose it comes with the postgreSQL installation.
I have again launched a postgresql clean-up and totale installation, and it is OK now.
A lot of issues because of connection roles to create not needed and password for twadmin to review.
Thank you all for your help.
Isabelle
Good to know that !
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
