Advice for design and implementation of the below architecture.
Sri1
Aquamarine
I needed suggestion on designing and IOT application.
I am going to describe it with an example flow which is similar to my existing requirement.
-> Consider there are 2 groups of users with a group head each. Each group have 4 members.
-> There are 4 machines and respective 4 things created in thingworx( whose parameters are linked to machine tags)
-> Each machine's data, information and related operations will be assigned to particular users from both the groups
-> There is one general mashup designed, which will should the respected machine information when the respected user login's to the application.
-> And there will be common set of services designed that will be linked to the mashup.
Question:
How to display data and information of different machines, when that respective user log's in the application(Mashup) on that same Mashup.
I have drawn a diagram for better understanding.
Now is need some advice on how to achieve this architecture .
Sri1
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
