We will host a live Expert Session: "Upgrade to Thingworx 9 – How to Plan / Evaluate Impacts" on January 12th 8h00 EST.
Please find below the description of the expert session and the registration link:
Expert Session: Upgrade to Thingworx 9 – How to Plan / Evaluate Impacts
Date and Time: January 12th 8h00 EST
Duration: 1 hour
Host: Ayush Tiwari - IoT Product Manager
Registration Here: https://www.ptc.com/en/customer-success/expert-sessions-for-thingworx-foundation-webcasts
Description:
This session will highlight the key points you should evaluate to properly plan your upgrade to Thingworx 9.
Existing Recorded sessions can be found on support portal using the keyword ‘Expert Sessions’.
You can also suggest topics for upcoming sessions using this small form.
Here are some recorded sessions that might be of your interest. You can find recordings for the full library of webinars using the keyword ‘Expert Sessions’ in PTC support portal search.
Thingworx Flow Overview Flow is a powerful component of the ThingWorx platform. This session will take the Flow discussion beyond basic applications and into more customized and complex solutions. This will focus on use cases, main features such as triggers, connector options, main enhancements for Thingworx 9.0 and a short demonstration |
Top 5 items to check for Thingworx Performance Troubleshooting How to troubleshoot performance issues in a Thingworx Environment? Here we cover the top 5 investigation steps that will help you understand the source of your environment issues and allow better communication with PTC Technical Support
Hi All,
Our expert session: Upgrade to Thingworx 9 – How to Plan / Evaluate Impacts is tomorrow (01/12/21)!!! Click the link below to register and remember to talk about it to colleagues that might benefit from its content:
See you there!
