Currently, as spoken with the support team, it seems impossible to create AppKey with REST API call at TWX.
It is possible to create a Thing that can do it, but I haven't found any way to put the Thing service code with API call either.
The issue is that I am working on automating the infrastructure integrity between TWX Platform and Analytics Server on Kubernetes/Docker and for Analytics Server to work I need to provide the AppKey before spinning up the Docker container - to be able to do that I need to be able to create AppKey and query an AppKey string programmatically (can be supplied and grabbed upon creation) so I can pass the key to the config before I spin up the Analytics Server environment.
