In PTC Navigate (using the View design Files app) , you are unable to see the document type, document number, version …. You only got the primary document.
PLM is implemented "part centric". Users should be able to search on the WTPart number and find the different WTDocuments.
Solution: Put the document attributes below the primary file of the WTDocuments
