The current ThingWorx Flow installer does not have the option to use an existing RabbitMQ instance and provides its own.
There are two problems with this configuration:
An example of point 2 above is the following: https://stackoverflow.com/questions/18495874/failed-to-create-cookie-file-rabbitmq-in-windows
This is a known issue with RabbitMQ: on some Windows systems it cannot be installed if the home drive is on a shared location, which causes the .erlang.cookie not being written during RabbitMQ installation.
This RabbitMQ problem can be overcome with a different RabbitMQ installation process, but the ThingWorx Flow installer does not allow changing it.
