Certain Analytics Errors (e.g. batch job failure) should show in the ThingWorx logs rather than the user having to get an id, then manually querying GetJobStatus.
In general, access to Analytics logs next to ThingWorx logs would be beneficial. The end user of TWX typically does not have RDP access to the TWX/Analytics machines.
