Thank you for publishing your idea. We need more information as specified in the form you saw in the submission process. (Questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. What version of Thingworx are you currently running? 2. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video. 3. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
Please find the details below in blue that you are looking . Let me know if you need any other information.
ThingWorx Navigate 9.3 2. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
In terms of authentication and authorization where ThingWorx, Thingworx Navigate and Windchill are involved, the existing integration with PingFederate can no longer continue as the ZF Organization wide decision is to decommission Ping and replace with Azure Active Directory for all the single sign on and Authentication/Authorization needs. This means that in the following months, ZF will be planning to replace Ping with Azure completely.
Hence, it is a hard requirement that Thingworx Navigate supports Azure AD as CAS for the integration.
The only way forward is to utilize Azure AD as CAS in the integration. PingFederate will soon be decommissioned.
Thank you @ankit3. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
