The main menu in Analytics Builder is Models, Signals, Profiles, Data.
The typical workflow is Data Upload, Creating Signals, Creating Profiles, Creating Models.
The predominant (western) UI flow is Left-to-Right, Top-to-Bottom (Z-Pattern or F-Pattern),
so the idea is to reorder the menu to Data, Signals, Profiles, Model to give new users the least "surprise".
