Composer Entity Browser - Add TAGS column and the Ability to Modify Tags from the Entity Browser
0 Kudos
I would categorize this suggestion under SYSTEM INTEGRATION and CONFIGURATION MANAGEMENT.
We have over 400 mashups alone and it is very time-consuming to find which ones have tags, what tags are assigned, find which ones need to have tags updated or changed, etc., without opening them one at a time.  Since there is already a great amount of space available, adding a TAGS column would display the assigned tags so we can quickly identify entities which need tag maintenance.  We tried using the DESCRIPTION field, but we discovered that anything in that field gets displayed in the browser when you mouse over the tab.  So we have started removing everything from that field.
**Bonus:  It would also a great time saver if you would add the ability to add and delete assigned tags from the entity browser without having to open them one at a time.
3 Comments
cbaldwin
Status changed to: Clarification Needed
@OldGoat  Are you using Tags to organize content and export by chance?  We believe projects in the later versions of ThingWorx are a good way to solve this.  We also have a new Project browser in Composer, and other filters in the interface to filter by Project.
olivierlp
Community Manager
Status changed to: Under Consideration
Will consider for a future release.
olivierlp
Community Manager
Status changed to: Archived
