When searching for entities in ThingWorx Composer it is currently necessary to type the entire and complete name of the entity or use a regex to find it. This is clunky and not industry standard. I propose the search use a more intelligent algorithm, searching inside names by default. The regex functionality can be moved to an advanced search as to not remove that utility.
For example, if I search for wrench:
I should see these options since they include the word wrench:
