Composer entity sorting as configuration (e. g. in user preferences)
Hello everyone,
I already submitted a case here but was forwarded to this idea page.
My issue: Thingworx Composer is always sorting entities by Date Modified, for alphabetical order I can use the column header or the highlighted button.
The issue here is that Thingworx always resets my selection as soon as I open an entity. From my point of view alphabetical order is more convenient most of the time, I find the desired entities much quicker. So at the moment I am forced to hit the button every time I am searching for something.
My idea: Make this configurable per user, e. g. in user preferences. This could look like this:
Of course this could be enhanced to also take any other sorting option into account.
If user preferences is not the right location I will be fine with it, too. As long as I have a permanent alphabetical order in the end I do not really care about the way to get there.
Thanks!
2 Comments
olivierlp
Community Manager
Status changed to: No Plans to Implement
Currently, when you sort a particular column and open an entity or switch to a different view, and come back, the sorting on the column persists. ThingWorx doesn't reset your sorting.
bbeuckSIG
It does. Good enough, thank you.
