When enabling SSO in Thingworx, all authenticators except "ThingworxSSOAuthenticator" (and optionally the Application Key authenticator) are disabled.
It would help being able to able to keep a custom authenticator enabled with a higher priority in order to allow for other forms of authentication.
Is it possible to not disable the custom authenticators when enabling SSO ?
