The collection widget allows us to show property information automatically on the screen for many things, without the need for manual intervention. The issue is that you can't use the new extendable containers or even dynamic panels widget inside of a collection cell, due to the height of the cell being fixed through the collection widget properties. This would be useful for drilling down into more detailed information or to split out the data for the cell you've clicked on. My proposal is that an option is added to the collection widget, that allows (at least) the height of each cell to change dynamically, maybe based on the height of the mashup it contains, so when you expand a container in the cell mashup, the cell grows with it.
