1. What version of Thingworx are you currently running?
9.2
2. Describe the problem you are trying to solve.
When executing a service that returns an Infotable in Composer, there should be an easy way to save the result to disk (e.g. as JSON). Where a service needs an infotable as input, there should be a "load" icon to load an table from disk as alternative to manually typing in cell by cell.
Developers currently have to use text-select and save, thereby losing all structure. There is even more hassle when paging is involved. This would save a lot of time and increase dev productivity, especially with Building Blocks as new default go-to architecture pattern, which relies heavily on configuration tables, an easy way of saving and loading those tables is needed, e.g. when working with different systems (dev,test,qa,...)
3. What business value would your suggestion represent for your organization?
Increase productivity by cutting down development time
Increase quality by reducing error made in manually re-typing in data which is already electronically available.
