Enablement of MPMLink Parallel/Alternate sequences in Operator Advisor
In an MPMLink Process Plan it is possible to represent the order of execution of operations in several ways.
To my knowledge there is no OOTB way to realise this in Operator Advisor. It is very common when planning to production to assess what operations can be done where/when depending on the capacity of a line or machine. Thus parallelism and alternates need to be used to reflect reality - especially if production is TAKT sensitive.
I have attached a image describing the simplest possible scenario I would like to achieve.
Question: Is there any roadmaps plans for such functionality in Operator Advisor?
1 Comment
olivierlp
Community Manager
Status changed to: Under Consideration
Yes, we are working on "routing"/Sequencing for the newer versions of the OA database. This functionality will contain Sequencing, qualifications and skill. You are correct, there is no OOTB way, as there is no concept of sequencing in OA today.
