1. What version of Thingworx are you currently running?
9.0.8
2. Describe the problem you are trying to solve:
I can't be sure when reading values in a VStream that the quality of the tag was GOOD, BAD or UNKNOWN when the property was logged. It would be nice to have this info logged with times and values. Otherwise, just the ability to skip bad/unknown quality values when choosing to log the property would be enough.
3. What business value would your suggestion represent for your organization?
I should used a workaround with Streams and I think this is not optimized as I should find the right trigger of the log and check the tag quality foreach property I want to log. Performance issues could appear with a large amount of tags I need to log.
