It is currently not possible to import a custom font and use it in a style theme as desired.
With a workaround, it is possible to use a custom font via custom CSS (https://www.ptc.com/en/support/article/CS322901) which is very inconvenient and most likely not applicable for all widgets (https://www.ptc.com/en/support/article/CS345809) .
Therefore, i suggest to add a simple import feature for fonts which can be used subsequently in every style theme.
