Improve Grid Sorting
1. What version of Thingworx are you currently running?
9.3+
2. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
We have large grids with multiple date fields (formatted to short dates) If the sort is enabled for the multiple date columns it stops working. The sort works fine with any other column. It will usually work for the first date column but after the second date column is clicked for sorting none of the columns will sort until you refresh the page.  Is there a work around that will make this work as I prefer being able to sort the column with having to use the query filter that reloads the data.
3. What business value would your suggestion represent for your organization? We could start using the client side filtering for fater sorting.
1 Comment
achirila
Moderator
Hi @gbell!
Thank you for your idea. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
