Looking at a project, the Entities page allows assigning Entities to the project.
This page needs improvement:
1) the column titles are disappearing when scrolling, they should be static.
2) the left side shows ALL entities, including ones that are already assigned to a project. So this is naturally a large list. Unfortunately, the filter does not allow to show only those entities, that need a project assignment the most: a) the ones without a project and b) the ones with a non-existing project (those can come in by import from another system). The request is to add filtering so I can see only the entities with no or an invalid project.
