Improve page auto-reload behaviour when jobs are running
When there is a Signals job running, the selected row is lost when the auto-reload hits, and the user has no control over it. The effect is that the details of a selected signal is only visible as long as there is no reload (which seems to be ca 10-15 seconds).
For signals, where the loading of the data takes longer, it's not possible to view the data at all.
Also (this is true for signals, profiles, models and datasets), when you create a new object with a job already running and you have the create dialog open, the auto-reload in the background window has the effect that any dropdown you have open in the dialog is closed. This makes it hard to select a value from any larger set, because reload might hit before the list is loaded of before you have navigated to the right position to select a value.
The idea is to preserve the selected row and not have reload influence the dialog
2 Comments
Rocko
Adding to this: When the auto-reload is active on the modeling page, you select a model and you click "delete model", and you aren't fast enough in clicking OK in the confirmation model, in the background the selected row has changed and you delete the wrong model. The confirmation dialog also does not display which model is going to be deleted.
olivierlp
Community Manager
Status changed to: Archived
