We need a fast way to inherit CSS code in multiple themes. This is possible by importing a CSS file (@import url("/Thingworx/FileRepositories/...") under the Custom CSS but that effects the loading time of the mashups drastically. With larger amount of CSS and contained-mashups the mashups will be unusable for the end user. We would like a general template that could be overriden by the themes.
We have tested multiple strategies to import CSS together with PTC support to maintaine the scalabillity with themes to be able to have multiples themes without copy the code between them without any luck.
