Given that JDK and JRE Checks only happen after the installer moves to installing the Service (near the end of the process)
Suggestion is that the JDK and Java Home is checked before copying files (fail early fail cheap)
This means that users can fix those issues
Checks I think that need to be performed
I can give you a PowerShell Script if needed
