The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Job info dialog alignment
0 Kudos
1)The Job Details dialog for model creation was fixed recently to contain the name of the selected job (C14086555).
This needs to be done respectively for the Job Details dialog  in Signals, Profiles and Dataset, so you see of which object you see the details.
2) Also, there is a “Description” field shown in those dialogs, but nowhere in Builder this field can be populated– when creating new objects, this is not offered. (It can only be done via API). So in almost all cases, this is empty, and it isn't helpful in display. Suggestion: Either do not display it, or have the opportunity to enter content in the job creation dialog.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
