Listing of Services and other Entities Used by Mashups
0 Kudos
1. What version of Thingworx are you currently running?
Currently using TWX 9.0.15.
2. Describe the problem you are trying to solve.
There is currently no way that I've found to compile a listing of services (Database, JavaScript), data shapes, media entities, style definitions, state definitions, etc. used by mashups without manually searching through each mashup.  This is very time consuming and tedious, and is easy to miss things.
3. What business value would your suggestion represent for your organization?
For integration and project management purposes (CMMI), it would make it easier to search for these entities that are used by other mashups for re-use.  It would also make it easier to find and remove services that are no longer used and identify services that duplicate functionality so we can merge them.
2 Comments
cbaldwin
Status changed to: Current Functionality
ThingWorx 9.3 has "Referenced By" feature which is like a Where Used.  I believe this would suit your needs.  Find more info here:  https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Composer/Refere...
OldGoat
cbaldwin,
Thank you for that!  Hopefully, we will be upgrading to 9.3.x sometime this year.  I've been reading the release notes.  It seems that this version has a lot of fixes and updates that I've been needing.
