Hi All,
I have an issue with SMTP Host. The SMTP Host has 4 different IP Addresses which are dynamic in nature.
Thingworx mail extension 3.6 has an issue that if connected to an IP address and it fails in connecting to that IP address. It does not try to connect to the other IP addresses and fails to send the mail. The SMTP Host also changes it IP Addresses periodically, so there is no constant IP address that it can depend to connect to the SMTP Host. Is there a permanent solution to this issue? If so, please advise.
P.S. Please include this email id (roshin.r@maxbytetech.com) when there is a reply regarding this idea.
