The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Make decimals and digits on gauge widget bindable
1. What version of Thingworx are you currently running?
9.3.1
2. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
The gauge widget has parameters for the number of decimals and number of digits to show for the value display on it. These overwrite the value supplied to it, meaning you cannot set a dynamic number of decimals and digits. As we are using a single mashup for the gauge widget with different mashup parameters (to allow reusability), the digits and decimals need to be different depending on the type of sensor that is supplied to it. Either enabling binding to these values and/or an option to use the formatting of the value supplied.
3. What business value would your suggestion represent for your organization?
This allows reusability, enabling faster setup of new projects. It also means the value being shown on the gauge is much more appropriate to the type of value being supplied to it.
1 Comment
RachelMc
11-Garnet
