Make flow workflow JavaScript service length configurable
Flow services have a hardcoded limit of 64 KB. It is sometimes necessary to create much longer, more complex JavaScript services. This limit should be configurable.
2 Comments
carloquinonez
6-Contributor
@smanley I was suggesting increasing the size ofTWX  JS Services, not Flow. Can you update the idea?
-- edit
Sorry I was getting confused between TWX JS services and Flow. Yes, we do want to use more than 64kb of JS code in Flow.
smanley
@carloquinonez I will follow up with you through email to clarify and align this Idea with the case.
