I have a situation where i deployed my project on a ThingWorx server (customer's premises), on which several other projects are present. Since most of the users are developers, they all need admin rights to import/export xml projects, extensions etc. This leads to a severe problem where different suppliers of the customer have access to each other's works. What Thingworx lacks here is a project based user management. In that case, each supplier has admin rights on it's own projects and not on others.
Please throw in your ideas on this.
Thank you.
