Need to change 3D view to display standard view instead of perspective view in Navigate apps?
0 Kudos
Prior versions of Navigate (1.4.1) displays the model without a perspective setting while the new Navigate (1.8.0) displays the same model in a perspective view.
When viewing the model in Windchill, it shows it in regular perspective (flat) while In Navigate it is showing in a perspective view. Need a setting to revert back to original standard view in order to make the experience consistent
Snapshots attached for reference
1 Comment
GrahamBirch
Status changed to: Delivered
There is a new version of the 3D viewer in Navigate 8.5. This viewer contains a number of enhancements including the ability to display PMI information and embedded menus to allow the user to easily switch between View States. In addition,  it shows Orthographic (standard) instead of Perspective.
Navigate 8.5 is due out by the end of the month so I'm setting the status of this request to "delivered" - a little premature but not by much.
Best Regards,
Graham
