Could you make the default styling of the Numeric Entry widget closer to that of the Text Entry / Text Area widgets? The font size on the Numeric Entry widget is a lot smaller and has some shading around it (see attached for comparison). It just looks inconsistent with the other entry widgets. Thanks.
