The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Saving Widget Properties in Thingworx Composer
0 Kudos
Currently to save a widget's property you enter the value, and hit tab/enter and then switch fields. To verify the property is properly saved, you can hover over the field and check the tooltip. I propose that fields be updated with the new value as soon as the user clicks 'Save' on the mashup, or switches focus away from that textarea. The current solution is clunky and not industry standard for saving values.
1 Comment
olivierlp
Community Manager
Status changed to: No Plans to Implement
Thank you. But no plans to implement at this time.
