The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Section Modulus of a part on an angle
0 Kudos
In Creo under X-section mass properties you can get the section modulus of a part and it works when you place a plane at section of the part that you want to get the section modulus of but you can not get the modulus of that section on an angle even if you put a new CSYS at an angle from vertical of the first CSYS. The modulus output is the same no matter the angle the part is at to vertical. Can you tell me if there is a work around for this problem so i don`t have to wait for the fix.
Thank you,
Kevin
2 Comments
cbaldwin
Status changed to: Clarification Needed
This appears to be for Creo, not ThingWorx.
olivierlp
Community Manager
Status changed to: Archived
