Dear all,
Thank you very much for the help of the community.
The fact that it's not possible to pass a parameter from the Dashboard to the custome Library to import gadget is a big issue. I read everywhere that we should use a session parameter, but it's not a functional answer, because it means that all the Dashboards need to have a different mashup to import gadget OR they will all use the same session parameter, which can really be problematic.
Can we hope for this feature to be implemented?
