In 8.3.3, I was able to open and work on multiple THING services (Javascript, Database). This allowed me to go back and forth between them so I could re-use code or work with two that had to work with each other. Additionally, the screen was compact and easy to read and work with.
With 8.5.1, I can only open one at a time. If I am working with two services that have to work with each other, I have to make a change in one, save and close it, open the other one, change it, save it, and close it, ad infinitum, ad nauseam...rinse and repeat. It is a great waste of time! Plus, the screen is spread out so it takes up my full monitor, wasting space. (See screen shots - my code is blocked out for security sake)
PLEASE PUT IT BACK THE WAY IT WAS IN 8.3.3!
