we're currently working on a project where the connection from SAP <-> TWX should be established through the Flow SAP Actions. Unfortunately we need to talk to the "Get Process Order" Module which isn't implemented yet. So I would like to suggest to expand the SAP actions to other common modules.
Because most of the time the SAP connectivity is causing quite a headache (and is time consuming) if no other option than standard RFC is given.
Thank you.
