Currently there are Thingworx Flow Installers for MS SQL and PostgreSQL. We are using a DoD certified cloud. This cloud environment gives us a more cost effective database through AzureSQL. Our use case is that we are in the process of performing a migration of the current database and image repository into a Windchill backed Thingworx Navigation application. Flow will be used to tie together WIndchill Workflows with Legacy database solutions for push/pull of data between all systems. Therefore, a Thingworx Foundation Installer for AzureSQL is needed.
