Currently there are Thingworx Foundation Installers for MS SQL and PostgreSQL. We are using a DoD certified cloud. This cloud environment gives us a more cost effective database through AzureSQL. Our use case is that we are in the process of performing a migration of the current database and image repository into a Windchill backed Thingworx Navigation application. Current 9.X versions of Navigate will not install unless one of the two mentioned Foundation installers are used first. Therefore, a Thingworx Foundation Installer for AzureSQL is needed.
