Validation Results Charts for Continuous Goals
0 Kudos
The validation results charts for continuous goals in the Analytics Builder can be quite confusing for the users. Basically, the bubble chart splits the validation results into different subsets depending on how far away from the actual value each point is. On the chart, we considering all predictions that are +/- 25% from the actual value as accurate. However, in a lot of use cases, a prediction that is 25% lower or higher is not considered accurate. It would be good if the users would be able to configure these limits so they can get a better visualization without having to export the validation results/use other tools/build their own Mashup. This would improve the visualization of the validation results for continuous goals and provide the user with more accurate charts.
2 Comments
olivierlp
Community Manager
Status changed to: Under Consideration
Will consider for future release.
olivierlp
Community Manager
Status changed to: Archived
