In Thingworx, when deleting a value stream it takes quite a lot of time, so there can be a provision made available to either show/get the progress (percentage) of deletion of value stream or a provision to show/get the size of Value stream we are planning to delete, so that a user can get a better idea if he would want to delete the value stream or not
