Thingworx 9 Composer has a nice feature for copying app keys, a small copy button (see attachment).
I suggest to add this to any place in builder where UIDs are used, mostly job IDs. Model job IDs must often be copied when working with the API.
Thanks for the input! While we may not be able to get the same UI widget into Builder, we are looking at adding similar functionality to ease the process of copying the ID values.
A new Copy Job ID button has been added to list pages for datasets, signals, profiles and models in 9.2
