tag any extension/widget during import with the name of the 'master' package.
0 Kudos
When importing an extension, all imported extensions get stored ThingworxStorage\extensions.  Any and all imported extensions/widgets should have metadata added to reference the exact directory under the extensions that references that extension/widget.  If the same widget is loaded by several packages, it should be tagged with all the referencing extensions or the last one it was loaded against.
1 Comment
olivierlp
Community Manager
Status changed to: No Plans to Implement
Thank you. But no plans to implement at this time.
