can someone help me.
I have seen this video on PTC Field Technical Enablement but unfortunately i have not found a demo file.I need e.g. PartSearchHelperThing for Data and etc.
Thank you
Hello Vladimir,
I am the creator and owner of this demo. Everything you need to run this demo is located in that demo location. After you've successfully set up the virtual machine on the demo page (located on the right of the demo page),
you'll be able to log into ThingWorx Composer and complete the demo, with all required configurations available, within the VM.
Who was the speaker at that moment?
But the first slide must have the speaker's name.
Hi Vladimir,
I found the creator and owner (Femi Koiki) of the files, but I can't reach him yet.
Hello Vladimir,
Thank you!
