Hello!
We will host a live Expert Session: "Understanding ThingWorx Navigate Licensing" on February 11th, 10h EST.
Please find below the description of the expert session and the registration link.
Expert Session: Understanding ThingWorx Navigate Licensing
Date and Time: February 11th, 10h EST
Duration: 1 hour
Host: Christoph Braeuchle, Emily Larkin and Steve Scheib - ThingWorx Navigate PM team
Registration Here: https://www.ptc.com/en/resources/plm/webcast/understanding-thingworx-navigate-licensing
Description:
ThingWorx Navigate licensing opens many users a way to access PLM data and functionality at an attractive price tag when they don’t need to use the full power of Windchill functionality. This licensing and packaging have changed over the past 1.5 years and this is the perfect time to share an update on available license types and answer essential questions like:
Don’t miss this session if you want to understand how ThingWorx Navigate licensing works and which options are available.
Existing Recorded sessions can be found on support portal using the keyword ‘Expert Sessions’.
You can also suggest topics for upcoming sessions using this small form.
Here are some recorded sessions that might be of your interest. You can find recordings for the full library of webinars using the keyword ‘Expert Sessions’ in PTC support portal search
Navigate - SSL & Windchill Authentication This in Expert Session will take you through a step-by-step approach for configuring authentication between Windchill and Navigate with SSL. |
Top 5 items to check for Thingworx Performance Troubleshooting How to troubleshoot performance issues in a Thingworx Environment? Here we cover the top 5 investigation steps that will help you understand the source of your environment issues and allow better communication with PTC Technical Support |
Thingworx 9.0 Component Based App Development Following the series of new capabilities released with Navigate 9.0, this session will focus in the details of Navigate Component Based app development and how to leverage this to your use cases |
The replay does not do a good job showing and progressing the slides. They are displayed in a smaller section in the corner and are not readable. Is there somewhere in the community where the slides are shared?
