Hi ,
i am using ESP8266 board., i followed the tutorial name "Connect an Arduino Developer Board" and used the code given in it. By using Arduino IDE i compiled and upload the code in it with necessary changes in code like WIFI SSID name, WIFI password, and in place of
const char TWPlatformBaseURL[] = "https://pp-2007011431nt.devportal.ptc.io";
the above code i have replaced it with my thing Worx server address which i am usually going to access it using url https://xxxxxxxx.thingworx.com
and app key. also i have created AND i have permitted the visibility of the resources to everyone in the thing Worx composer and i have followed each and every step given in the ptc tutorial but still my esp8266 board is not connecting to thing Worx, please help me still what changes I need to do in my code or what needs to be done in thing Worx ......
here is the code which i have compiled in my Arduino ide
/** * * ESP8266_ThingWorx_REST_Demo.ino * * * (c) PTC, Inc. 2016-2020 * */ #include <Arduino.h> #include <ESP8266WiFi.h> #include <ESP8266HTTPClient.h> #include <WiFiClientSecureBearSSL.h> ////////////////////// // WiFi Definitions // ////////////////////// const char WiFiSSID[] = "shree"; // WiFi access point SSID const char WiFiPSK[] = "shreeexxxxx"; // WiFi password - empty string for open access points ////////////////////////////////////////////// // ThingWorx server definitions // // modify for a specific platform instance // ////////////////////////////////////////////// const char TWPlatformBaseURL[] = "https://xxxx-dev-twx.es.Thingworx.com"; const char appKey[] = "26e717cf-b1f0-466d-8d86-403de15xxxxxx"; //////////////////////////////////////////////////////// // Pin Definitions - board specific for Adafruit board// //////////////////////////////////////////////////////// const int RED_LED = 0; // Thing's onboard, red LED - const int BLUE_LED = 2; // Thing's onboard, blue LED const int ANALOG_PIN = A0; // The only analog pin on the Thing const int OFF = HIGH; const int ON = LOW; // this will set as the Accept header for all the HTTP requests to the ThingWorx server // valid values are: application/json, text/xml, text/csv, text/html (default) #define ACCEPT_TYPE "text/csv" ///////////////////// //Attempt to make a WiFi connection. Checks if connection has been made once per second until timeout is reached //returns TRUE if successful or FALSE if timed out ///////////////////// boolean connectToWiFi(int timeout){ Serial.println("Connecting to: " + String(WiFiSSID)); WiFi.begin(WiFiSSID, WiFiPSK); // loop while WiFi is not connected waiting one second between checks uint8_t tries = 0; // counter for how many times we have checked while ((WiFi.status() != WL_CONNECTED) && (tries < timeout) ){ // stop checking if connection has been made OR we have timed out tries++; Serial.printf(".");// print . for progress bar Serial.println(WiFi.status()); delay(2000); } Serial.println("*"); //visual indication that board is connected or timeout if (WiFi.status() == WL_CONNECTED){ //check that WiFi is connected, print status and device IP address before returning Serial.println("WiFi connected"); Serial.println("IP address: "); Serial.println(WiFi.localIP()); return true; } else { //if WiFi is not connected we must have exceeded WiFi connection timeout return false; } } ////////////////////////// //create a name for the board that is probably unique by appending last two bytes of MAC address //return name as a String /////////////////////////////// String getUniqueDeviceName(){ String uniqueName; uint8_t mac[WL_MAC_ADDR_LENGTH]; WiFi.macAddress(mac); // WiFi does NOT need to be connected for this call String macID = String(mac[WL_MAC_ADDR_LENGTH - 2], HEX) + String(mac[WL_MAC_ADDR_LENGTH - 1], HEX); macID.toUpperCase(); uniqueName = "ESP8266Board-" + macID; Serial.println("DeviceID>" + uniqueName); return uniqueName; } /////////////////////////////// // make HTTP GET to a specific Thing and Propertry on a ThingWorx server // thingName - Name of Thing on server to make GET from // property - Property of thingName to make GET from // returns HTTP response code from server and prints full response /////////////////////////////// int httpGetPropertry(String thingName, String property){ std::unique_ptr<BearSSL::WiFiClientSecure>client(new BearSSL::WiFiClientSecure); client->setInsecure(); HTTPClient https; int httpCode = -1; String response = ""; Serial.print("[httpsGetPropertry] begin..."); String fullRequestURL = String(TWPlatformBaseURL) + "/Thingworx/Things/"+ thingName +"/Properties/"+ property +"?appKey=" + String(appKey); https.begin(*client,fullRequestURL); https.addHeader("Accept",ACCEPT_TYPE,false,false); Serial.println("GET URL>" + fullRequestURL +"<"); // start connection and send HTTP header httpCode = https.GET(); // httpCode will be negative on error if(httpCode > 0) { response = https.getString(); Serial.printf("[httpGetPropertry] response code:%d body>",httpCode); Serial.println(response + "<\n"); } else { Serial.printf("[httpGetPropertry] failed, error: %s\n\n", https.errorToString(httpCode).c_str()); } https.end(); return httpCode; } /////////////////////////////// // makes HTTP POST to platform to CreateThing service using input string as the new Things's name. // Returns server response code /////////////////////////////// int createThing(String nameOfThing){ std::unique_ptr<BearSSL::WiFiClientSecure>client(new BearSSL::WiFiClientSecure); client->setInsecure(); HTTPClient https; int httpCode = -1; String response = ""; Serial.print("[createThing] begin..."); String fullRequestURL = String(TWPlatformBaseURL) + "/Thingworx/Resources/EntityServices/Services/CreateThing?appKey=" + String(appKey); https.begin(*client,fullRequestURL); https.addHeader("Accept",ACCEPT_TYPE,false,false); https.addHeader("Content-Type","application/json",false,false); Serial.println("POST URL>" + fullRequestURL + "<"); // start connection and send HTTP header httpCode = https.POST("{\"name\": \""+ nameOfThing +"\",\"thingTemplateName\": \"GenericThing\"}"); // httpCode will be negative on error if(httpCode > 0) { response = https.getString(); Serial.printf("[createThing] response code:%d body>",httpCode); Serial.println(response + "<\n"); } else { Serial.printf("[createThing] POST... failed, error: %s\n\n", https.errorToString(httpCode).c_str()); } https.end(); return httpCode; } /////////////////////////////// // make HTTP POST to ThingWorx server Thing service // nameOfThing - Name of Thing to POST to // endPoint - Services URL to invoke // postBody - Body of POST to send to ThingWorx platform // returns HTTP response code from server /////////////////////////////// int postToThing(String nameOfThing, String endPoint, String postBody){ std::unique_ptr<BearSSL::WiFiClientSecure>client(new BearSSL::WiFiClientSecure); client->setInsecure(); HTTPClient https; int httpCode = -1; String response = ""; Serial.print("[postToThing] begin..."); String fullRequestURL = String(TWPlatformBaseURL) + "/Thingworx/Things/"+ nameOfThing +"/Services/"+ endPoint +"?appKey=" + String(appKey); Serial.println("URL>" + fullRequestURL + "<"); https.begin(*client,fullRequestURL); https.addHeader("Accept",ACCEPT_TYPE,false,false); https.addHeader("Content-Type","application/json",false,false); Serial.println("[postToThing] POST body>" + postBody + "<"); // start connection and send HTTP header httpCode = https.POST(postBody); // httpCode will be negative on error if(httpCode > 0) { response = https.getString(); Serial.printf("[postToThing] response code:%d body>",httpCode); Serial.println(response + "<\n"); } else { Serial.printf("[postToThing] POST... failed, error: %s\n\n", https.errorToString(httpCode).c_str()); } https.end(); return httpCode; } void setup() { pinMode(RED_LED, OUTPUT); pinMode(BLUE_LED, OUTPUT); Serial.begin(115200); Serial.setDebugOutput(true); Serial.println(); Serial.println(); Serial.println(); Serial.printf("Starting...\n"); for(uint8_t t = 4; t > 0; t--) { Serial.printf(" WAIT %d...\n", t); Serial.flush(); delay(1000); } connectToWiFi(10); } void loop() { String thingName = getUniqueDeviceName(); //unique name for this Thing so many work on one ThingWorx server while (WiFi.status() == WL_CONNECTED) { //confirm WiFi is connected before looping as long as WiFi is connected int getResponseCode = httpGetPropertry(thingName, "SomeNumber"); if (getResponseCode == 404){ // a 404 means connected, but either no Thing or no property // first we will try to create a new Thing on the platform int postResp = createThing(thingName); // saving the response code for retry logic in the future // the newly crated Thing has to be enabled postResp = postToThing(thingName,"EnableThing",""); //POST to EnableThing endpoint with no body // after the new Thing is enabled it must be restarted postResp = postToThing(thingName,"RestartThing",""); //POST to RestartThing endpoint with no body // add a property to the Thing 3rd parameter is ugly because required quotes are escaped with backslashes postResp = postToThing(thingName,"AddPropertyDefinition", "{\"name\":\"SomeNumber\",\"type\":\"NUMBER\"}"); //POST body contains JSON object with property name and property type // after changes to a Thing's structure it must be restarted postResp = postToThing(thingName,"RestartThing",""); //POST to RestartThing endpoint with no body } delay(2000); }// end WiFi connected while loop Serial.printf("****Wifi connection dropped****\n"); WiFi.disconnect(true); delay(10000); connectToWiFi(10); }t
Hi @NH_shree.
Have you checked the logs for errors? You will find the ThingWorx logs in ...\ThingworxStorage\logs.
If you're not seeing anything in the ThingWorx logs, you may have a network issue preventing the device from connecting.
Let us know if you're not able to make any progress.
--Sharon
Hi @NH_shree.
--Sharon
