The following css style is applied to the grid widget, but the button does not position well.
.pos {
margin-top: 30%;
height: 30ch;
When fixing the position of a widget, is it common to specify a position with a grid widget and then include the widget in it?
Any other good suggestions?
regards
Yes, it is recommended to use the grid widget to help with positioning of widgets.
If so, do you specify as many as% when specifying the location?
Or do you recommend positioning in px?
I have found specifying in px works well.
