Which kind of formats could I import in ThingWorx Studio for animations or sequences?
efraga
Hello everybody ,
I saw a similar question about this topic in this forum but there is not an answer about it , I would like to know if it possible to import file for example .FBX files or if I have to use exclusively Creo Illustrate ?
Elias
mwassmann
(To:efraga)
Elias,
the getting started guide would help. But also the help answers that.
Remember when using different formats you won't have the technical illustrations/sequences.
You could import them through creo illustrate as well and animate them accordingly ... e.g. if you think about formats like JT / or other cad formats - that would be one way to go .
Martin
mwassmann
(To:efraga)
Elias,
Martin
efraga
(To:mwassmann)
Hi Martin,
It is clear enough the information that you shared with me , thank you very much for your help
