Donwload representation files
SOLVED
Newbie
Hello everyone, I have to build a Custom App in PTC Navigate 1.5.2 that can download Windchill representable files (ex pvz, pvs).
I already have a Java class that query Windchill and extract representation download URL; now I wondering if it is possible use some service already defined in Navigate or I must write a my own extension.
Another question is how i can develop a Thingworx extension that can use the Windchill API.
Thank you Giorgio
Re: Donwload representation files
You can use the ExecuteTask service on the (legacy) WindchillConnector to invoke a custom I*E tasks on the Windchill system (directly call your custom Java code from the custom I*E task). This service may become deprecated at some point and a custom Windchill REST Service is the way to go in the long run.
You can also test the GetCreoViewData service on the WindchillConnector, it may directly return the Representation URL.
This should be doable using REST APIs in Windchill REST Services 1.0  take a look here https://support.ptc.com/WCMS/files/173713/en/WCCG_RESTAPI.pdf for more info
thank you Marek, surely RestApi is the solution now i'm going to investigate if is it possible to customize a RESTfull call
Thank you stephane, as i have just told to Marek i'm going to investigate if it is possible to customize te RESTfull call otheriwse i'll use the I*E task
